Occasionally we’ve been getting questions about the Datamate L-Tek from Harwin,specifically the M80-888 connectors that come with sockets included. If something happens to your assembly and you need to replace individual wires or contacts, the correct part number is 952-1048-ND, which takes 24-28AWG. If it’s necessary for some reason, you could also replace it with part number 952-1049-ND which is for 22AWG since the housing is the same design for both. Hope this helps!
