I’m looking for a Micro D-Sub connector that adheres to Mil Spec M83513/01-BN. I was looking at the one made by ITT Cannon, LLC, which looks like the correct one, however the manufacturer part number that DigiKey provides is just the Mil Spec number, which appears nowhere in the provided datasheet as a decodable part number. I would like to make sure I am ordering the right part.
Here is a link to the part: M83513/01-BN ITT Cannon, LLC | D-Sub Connector Assemblies | DigiKey
Can anyone clarify this for me?
Thanks
Welcome to the TechForum!
Hey Gabriel, I think you sent an email regarding this too. I did send an answer regarding that recently. In case you did not see that:
I do think you are ordering the right part. The datasheet does mention on page one that the series is design to MIL-DTL-83513 specifications. The extra suffix numbers are often copied from the actual MIL Spec in the part numbers, but may not always be found in the actual datasheet, especially for COTS parts. In this case, the datasheet does explain the part breakdown on page 36.
