I am trying to find out what the part number for these pins circled in red are
I can take measurement of the male connector as well, so that the length of the pin and width of the pin can help with narrowing done what kind of connector it is
Yes please provide measurements.
I want to recommend something like this. Click HERE. The plastic housing for the sockets on the bottom of the board might be custom
Best regards!
It would be nice to see the back of the circuit board, to see how large the bottom of the pins are.
Some possible options are part numbers ED90079-ND, ED5014-ND, and ED11313-ND. These can be used with a male pin between 0.81~1.17mm diameter.
Please check the datasheet to verify the dimensions and compatibility to your application.
i think the black component on the back of the pcb is just a 3d printed part, i am not sure how far those pins stand off of the back of the pcb
