Magnetic core property of the LVDT
Hi,
I purchased the LVDT HR 500, the link is https://www.digikey.com/en/products/detail/te-connectivity-measurement-specialties/02560394-000/638042 .There is a magnetic core that comes with the LVDT.
May I have the magnetic properties, such as the magnetic permeability, of the magnetic core?
Thank you for your help!
Hello DigiProductInquiry ,
Thank you for reaching Digi-Key TechForum. I have reached out to the appropriate manufacturer representatives and will post the response once received, please let us know if you have any further questions.
Thank you for the help! I look forward to hearing from you.
DigiProductInquiry,
Thank you for your patience, we are still awaiting a response from the manufacturer.
Hello @DigiProductInquiry ,
Thank you for your patience on this. Please see below manufacturer response:
“The core is a Nickel-Iron ferromagnetic alloy. I don’t have detailed property information on this type of alloy. They are designed for optimal performance with our LVDT’s.”
