We are buying 2 items from you.
100-18946-10- CONN SOCKET 16-18AWG GOLD CRIMP- Manufacture item# SC16ML-1D70 by SOURIAU
100-18946-20- CONN SOCKET 20-22AWG GOLD CRIMP- Manufacture item# SC20ML-1D70 by SOURIAU
Our customer raised a queries as below Yellow highlighted and requesting you to provide a quick information as we are holding .
Do they have a shorter contact, or a contact with the same length but a bit deeper? The current length/depth is 19mm based off the datasheet
We are working on the first build , but these contacts only use about half the pin length in the connector due to a stop in the socket, and we are running out of room in the strain relief as a result.
Please provide quick solution.
