Maximum number of Microphones which can be interfaced with WM8994
Hello ,
I am working on an Audio solution and wanted to know if 4 Mics(I2S or PCM) can be interfaced with WM8994_Rev4.6.pdf ? I see it has PCM1,2 and 3 block but on the left it says 4 Digital MICS?
Can you please clarify with the connection interfaces?
Also if I want to stream all the MICs data at 48 or 96Khz to an application processor which interface should I chose?
Regards,
S
Page 57, documents how 2 digital MICS are multiplexed into each DMICDATx pin..
Looking at Page 59, i don’t see you getting 96Khz:
Regards,
Thanks for the facts @RobertCNelson . I will check this.
Br,
S
