We purchased the part number MCOT064032A1V-YI from DigiKey.
However, we noticed that the datasheet does not specify the VBAT voltage specification. Could you please help confirm the VBAT specification range for this device?
In addition, could you please advise :
- What is the minimum VBAT voltage requirement?
- Our customer’s design uses 3.3V for VBAT. Is this acceptable for this device?
Hello han.huang,
I’m asking for more information on this and some clarification. I’ll get back to you once I have some more feedback. In the mean time, someone else might be able to answer your question.
Thank you for your inquiry.
The display IC the MCOT064032A1V-YI uses is SSD1306BZ, which has an internal charge pump DC to DC converter.
To pull up the datasheet for that chip you can do a search for “SSD1306BZ Midas Display” online.
It’s optimized for a single cell li-po battery or similar.
Thank you for your help and the information!
