Microchip PIC32CM Curiosity Nano (El camino a Zephyr Parte 1)
El propósito de esta serie de artículos, es crear demos relacionados al sistema operativo de tiempo real Zephyr en el Arm Cortex-M0+ MCU de la plataforma Microchip PIC32CM PL10-CNANO evaluation board
La plataforma Microchip PIC32CM PL10-CNANO evaluation board contiene un PIC32CM6408PL10048 con las siguientes características,
El Arm® Cortex-M0+ MCU demuestra bajo consumo de potencia, capacidades flexibles análogas, cronómetros avanzados, y opciones de comunicación versátiles. A continuación se muestran muchos de los aspectos relacionados a esta plataforma,
• Arm Cortex-M0+ Core with Speeds up to 24 MHz Across a Supply Voltage Range of 1.8–5.5V
• 64 KB In-System Self-Programmable Flash with 8 KB SRAM
• Operating Voltage: 1.8–5.5V
• Available in 48-Pin TQFP and 48-Pin VQFN WF Packages
• Low Power
– Idle and Standby sleep modes
– Sleep Walking peripherals
• Multi-Voltage I/O (MVIO)
• Peripheral Touch Controller (PTC) with 25 Self-Capacitance Channels
• One 12-bit, 800 ksps Analog-to-Digital Converter (ADC)
• Two Analog Comparators (AC) with Window Compare Function
• Four 16-bit Timer/Counters:
– Three 16-bit basic Timer/Counters (TC0-2)
– One 16-bit Timer/Counter for Control with four PWM channels (TCC0)
• 32-bit Real Time Counter (RTC) with Clock/Calendar Function
• Two Serial Communication Interfaces (SERCOM), Configurable to Operate as:
– USART with full-duplex and single-wire half-duplex configuration
– ISO7816 UART
– I2C up to 1 MHz (SERCOM0)
– SPI
– LIN Host/Client
– RS-485
• Two-Channel Direct Memory Access Controller (DMAC) with CRC Generator
• Four-channel Event System (EVSYS)
• Configurable Custom Logic (CCL) with Four Look-Up Tables (LUT)
• Programming and Debugging Interface Disable (PDID) Functionality
• Watchdog Timer (WDT)
• External Crystal Oscillator with Failure Detection
• Integrated Temperature Sensor
• Temperature Ranges:
– Industrial: −40°C to +85°C
Los puertos externos de esta plataforma Microchip PIC32CM PL10-CNANO evaluation board se muestran a continuación,
La siguente foto presenta los aspectos principales de la plataforma,
Aquí está el diagrama de bloque de la plataforma Microchip PIC32CM PL10-CNANO evaluation board,
Mantegase sintonizado para nuestro próximo artículo del sistema operativo de tiempo real Zephyr en esta plataforma de evaluación de Microchip. La plataforma Microchip PIC32CM PL10-CNANO evaluation board es de bajo costo y a misma vez poderosa la cual está disponible DigiKey.
Que tenga un buen día.
Este artículo está disponible en inglés aquí.
This article is available in english here.
