Introduction
There are plenty of reasons to replace the microcontroller (MCU) in an existing design. Cost, availability, power consumption, performance, new functionality or long-term platform needs can all start the conversation. When lead times and pricing become unpredictable, the impact goes beyond component availability, it can put design schedules, production plans and time-to-market at risk.
Once it starts, the first question is usually: “What Microchip MCU is comparable to the device I’m using today?”
That question is a good place to begin, but it is rarely where the work ends. Migrating to a new MCU can impact hardware, firmware and development timelines, and most of the surprises come from treating it as a simple part swap. This post covers where to start and the common pitfalls to watch for along the way.
Start With What the Design Actually Needs
The most useful first step happens before you search for a single part. Write down what the existing application depends on: memory, performance, peripherals, real-time behavior, external hardware dependencies and firmware portability.
This baseline is easy to skip, and skipping it is the first common pitfall. Without it, comparing candidates becomes guesswork, and it is hard to predict where hardware or software changes will be needed. With it, every later step has something concrete to measure against.
Build a Shortlist, Not a Final Answer
With requirements in hand, the Microchip Cross Reference Tool is a quick way to narrow the portfolio. Enter your existing device, and the tool identifies comparable Microchip MCUs based on key device characteristics and shows device availability. Check current DigiKey listings for specific part numbers, stock and lead times rather than relying on portfolio-wide availability estimates.
Engineers should avoid reading the result as a drop-in replacement. A cross-reference result is a list of potential devices worth evaluating, not a guarantee of a direct one-to-one replacement. The tool helps identify comparable characteristics, memory and performance similarities and available alternatives. You still need to check:
- Pin and package compatibility
- Peripheral implementation differences
- Software and driver compatibility
- Application-specific requirements
If you want a second opinion on the shortlist, Microchip FAEs and sales teams can help evaluate device options and identify the best fit for the application. Explore available Microchip MCUs on DigiKey and verify the stock and lead time of each candidate.
Expect the Software to Need Work
Another common challenge is underestimating how much code will change. MCUs from different vendors and device families are rarely identical, so differences in architecture, peripherals and software typically require some development work. Peripheral configuration, pin assignments, initialization code, drivers or libraries may all need to be adapted.
For example, moving an existing Arm® Cortex®-M based application to a PIC32CM MCU may require reviewing peripheral mapping, clock and pin configuration and adapting portions of the existing software. Microchip’s Migration Series, available as migration documents and videos, explains what to expect and the differences you may encounter, so you can plan for them instead of finding them during debug.
Use AI to Move Faster, Not to Skip Steps
The MPLAB® AI Coding Assistant, integrated into Visual Studio Code, can help you understand unfamiliar code, answer Microchip-specific development questions and develop or adapt software for the new device. The MPLAB AI Coding Assistant video series shows additional examples of how to use it.
The drawback is expecting it to handle the migration for you. AI does not eliminate the engineering work involved. It helps you understand the new platform and move through software development more efficiently, but you still need to review the generated or modified code and test it on the target hardware.
Don’t Stop When It Compiles
One of the easiest mistakes to make late in a migration is calling it done once the application compiles or the new MCU is on the schematic. The hardware implementation still needs to be reviewed and validated.
MicroCHECK provides access to Microchip design-review expertise for supported Microchip products. For supported 32-bit PIC® and SAM MCU designs, it offers an additional review of the hardware implementation before moving further toward production. You should also test the migrated firmware on the target hardware to verify peripheral operation, timing and application-specific behavior.
Consider the Best Part, Not Just the Closest One
The final drawback is a missed opportunity rather than a mistake. The closest device on paper may not be the best fit. A better-suited MCU may provide lower power consumption, more integrated peripherals, additional memory or functionality that can help reduce system cost, remove external components or add new capabilities.
So instead of asking only, “What replaces the MCU I have today?”, it can be worth asking “What Microchip MCU provides the best solution moving forward?”
Where to Go From Here
Replacing an MCU is a process, and each stage has a resource to support it:
- Identify potential alternatives with the Cross Reference Tool.
- Understand the migration path with the Migration Series documents and videos.
- Adapt and develop software with the MPLAB AI Coding Assistant.
- Validate the design with MicroCHECK.
Every migration is a little different. If you have worked through one, the lessons you learned along the way are worth sharing with others who are just getting started.
Looking for your next MCU? Explore Microchip MCUs available through DigiKey, compare potential alternatives with the Cross Reference Tool, and use the available development resources and engineering support to help keep your design moving.
