Mikroprog for pic driver
Part# 1471-1288-ND
Mfg# MIKROE-764
MFG MIKROELEKTRONIKA ROHS3 Comp
down loaded the driver : http://www.mikroe.com/downloads/get/1202/mikroprog_for_pic_drivers_v200.zip
And also have installed the mikroprogsuite for PIC
using www.mikroe.com/downloads/get/1201/mikroprog_suite_for_pic_v230.zip
Problem: The driver is not linking to my computer with a PC via USB cable.
I have window10
Hi Youngko,
Thank you for your inquiry.
That download link does not look like the current drivers they’re showing for this device. They can be found here under ‘Downloads’ Click here for Downloads including Drivers
The only choice you need to make is if you’re running Windows 10 32Bit or 64Bit.
Hi Thank you for responding to me so soon.
I did used that site as well.
And no luck.
still no link between pc and the driver.
This is what I see
It’s a Windows 10 permissions and/or driver signature verification problem.
This support page has the solutions.
https://helpdesk.mikroe.com/article/865-issues-with-drivers-for-windows-10
That solve the problem.
Thank you
