------Question for MMBT2907AT-7-F Please Put your question below------
Are there MMBT2907AT-7-F PNP transistors available with nonstandard pinout arrangement? i.e. the collector and emitter leads location on the package are interchanged.
Additional information, the required MMBT2907AT-7-F equivalent transistor is in sot 523 and requires pin 3 - Emitter and pin 2 - Collector.
Greetings,
Available listings for single PNP BJTs in SOT523 package can be found here.
I’d suggest applying any additional filters that govern your specific concept of “equivalent” and checking if any of the remaining results have the desired pin configuration.
Hi Rick,
Thanks for your response. The search results you sent are all pinout:1-Base, 2-Emmiter, 3-Collector configuration. What i require is a PNP transistor in STO523 but with 1-Base, 2-Collector, 3-Emitter configuration.
Searching for a non-standard pinout it not a searchable parameter.
As the configuration that you are looking for is not common, you may need to work with a supplier to see if it is possible to get you the design that you require.
