Modular Soldering Workstation (80/20 + MultiBoard/MultiBuild) - Product Purchases
The Hardware
T-Slot Aluminum Extrusions
Expand to see product information
MFR PART # 1010-72
DIGIKEY PART # 4876-1010-72-ND
MANUFACTURER 80/20, LLC
DESCRIPTION The 1010-72 from 80-20, LLC is a 1″ × 1″ fractional 10-series square T-slotted aluminum profile provided as a 72-inch stock bar. It features four open T-slots—one on each face—allowing versatile access for mounting from any direction. Designed with handy align-a-grooves for precise joining, this extrusion is compatible with all 10-series fasteners and is ideal for lightweight framing applications such as machine guards, sound enclosures, workbenches, displays, and panel-mount racks. Crafted from 6005A-T61 aluminum, it strikes a balance between strength, low weight, and corrosion resistance—making it both sturdy and easy to work with.
DATASHEET Click Here
What we need:
Quantity Part of Assembly Name Length Stick A Stick B
4 T-Slot Long Vertical Support 300mm x x x x
2 T-Slot Long Horizontal Support 600mm x x
2 T-Slot Short Vertical Support 200mm x x
2 T-Slot Short Horizontal Support 200mm x x
Since each length comes in 72" (1828.8mm), two lengths are needed. Most folks will not need me to mention this but I will anyway; make sure to account for the thickness of the cutting blade when measuring and before cutting.
Fasteners
Quantity Used: 11
MFR PART # PMSSS 832 0075 PH
DIGIKEY PART # H718-ND
MANUFACTURER BFirst Industrial
DESCRIPTION #8-32 Pan Head Machine Screw Phillips Drive Stainless Steel
Quantity Used: 96
MFR PART # PMSSS 832 0050 PH
DIGIKEY PART # H716-ND
Quantity Used: 20
MFR PART # PMSSS 832 0038 PH
DIGIKEY PART # H715-ND
Quantity Used: 127
MFR PART # HNSS 832
DIGIKEY PART # H726-ND
DESCRIPTION #8-32 Hex Nut 0.344" (8.74mm) 11/32" Stainless Steel
Quantity Used: 1
MFR PART # PMSSS 632 0025 PH
DIGIKEY PART # H708-ND
DESCRIPTION #6-32 Pan Head Machine Screw Phillips Drive Stainless Steel
NOTE: Do not order in the quantities listed above. These often times come in quantities of 100 pieces when you purchase 1 piece.
Rubber Feet
Quantity Used: 4
MFR PART # SOF-15129
DIGIKEY PART # RPC5103-ND
MANUFACTURER Essentra Components
DESCRIPTION Foot Cylindrical, Recessed Center 0.626" Dia (15.90mm) Rubber, Neoprene Black
Heat-set Threaded Inserts
Quantity Used: 8
MFR PART # H832X185C
DIGIKEY PART # 2254-H832X185C-ND
MANUFACTURER Tri-Star Industries, Inc.
DESCRIPTION Insert Yellow 0.28" Dia x 0.19" H (7.1mm x 4.7mm)
Electronic Components
USB Power Supply
MFR PART # QFWC-10-05
DIGIKEY PART # Q1253-ND
MANUFACTURER Qualtek
DESCRIPTION 5V 10 W AC/DC External Wall Mount (Class II) Adapter Fixed Blade Input
PD Capable Power Supply
MFR PART # SC1158
DIGIKEY PART # 2648-SC1158-ND
MANUFACTURER Raspberry Pi
DESCRIPTION 9V, 12V, 15V 27 W AC/DC External Adapter Multi-Blade (Single Blade Included) Input
Fan
MFR PART # F1238E12BT-FSR-CC
DIGIKEY PART # 1570-1527-ND
MANUFACTURER Mechatronics Fan Group
DESCRIPTION Fan Tubeaxial 12VDC Square - 119mm L x 119mm H Ball 126.0 CFM (3.53m³/min) 2 Terminals
Surge Protector
MFR PART # TLP404
DIGIKEY PART # TL313-ND
MANUFACTURER Eaton Tripp Lite
DESCRIPTION Outlet Strip, Power Strip, Surge Protector 390J Bench, Floor, Wall
PD Voltage Conversion Board
MFR PART # 5807
DIGIKEY PART # 1528-5807-ND
MANUFACTURER Adafruit Industries LLC
DESCRIPTION HUSB238 - USB Type-C Power Delivery (PD) Power Management Evaluation Board
Rocker Switch
MFR PART # PRASA1-16F-BB0BW
DIGIKEY PART # 450-1810-ND
MANUFACTURER TE Connectivity ALCOSWITCH Switches
DESCRIPTION Rocker Switch SPST 16A (AC) 125 V Panel Mount, Snap-In
Consumables
Solder
I designed the solder holder to hold a 1lb (500g) spool of solder. I have included a link one option below but there is also a link to other options as well.
Click here to see options on the DigiKey website
MFR PART # SMDSWLF.059 3.3 1LB
DIGIKEY PART # 315-SMDSWLF.0593.31LB-ND
MANUFACTURER Chip Quik Inc.
DESCRIPTION Lead Free No-Clean, Water Soluble Wire Solder Sn96.5Ag3Cu0.5 (96.5/3/0.5) Spool, 1 lb (453.59g)
MFR PART # DKS-SLDWK
DIGIKEY PART # DKS-SLDWK-ND
MANUFACTURER DigiKey Standard
DESCRIPTION Desolder Braid/Wick No Clean Blue 0.098" (2.50mm) 10’ (3.048m)
Soldering Iron Tip Tinner
MFR PART # SMDTCLF
DIGIKEY PART # SMDTCLF-ND
DESCRIPTION Lead Free Solder Tip Tinner (Activator) For Use With Soldering Irons, Workstands 1.57" Dia x 0.57" H (40.0mm x 14.5mm)
Flux Pen
MFR PART # DKS-FLUXPEN10ML
DIGIKEY PART # DKS-FLUXPEN10ML-ND
DESCRIPTION Flux - No Clean
Hook-up Wire
MFR PART # 11367
DIGIKEY PART # 1568-11367-ND
MANUFACTURER SparkFun Electronics
DESCRIPTION Hook Up Wire, 22 AWG Kit 6 Spools, 25 ft each(Solid)
MFR PART # 11375
DIGIKEY PART # 1568-11375-ND
DESCRIPTION Hook Up Wire, 22 AWG Kit 6 Spools, 25 ft each (Stranded)
Carbon Filters For Fume Extractor
MFR PART # WSA350F
DIGIKEY PART # WSA350F-ND
MANUFACTURER Apex Tool Group
DESCRIPTION FILTERS CARBON FOR WSA350 3/PK
Mounted Tools
Multimeter
MFR PART # 18341
DIGIKEY PART # 1568-18341-ND
DESCRIPTION Auto/Manual Average Handheld Digital (DMM) Multimeter 4.0 Digit LCD Display Voltage, Current, Resistance, Capacitance, Temperature, Frequency Continuity, Diode Test Function Features Auto Off
Soldering Station
MFR PART # IF145-494-1
DIGIKEY PART # 2434-IF145-494-1-ND
MANUFACTURER iFixit
DESCRIPTION FIXHUB PORTABLE SOLDERING STATIO
Solder Sucker
MFR PART # 148
DIGIKEY PART # 1528-148-ND
DESCRIPTION Desolder Pump With Tip Silver
Tweezers
MFR PART # 10602
DIGIKEY PART # 1568-10602-ND
DESCRIPTION Tweezers ESD Safe Pointed Very Fine 4.72" (120.0mm)
MFR PART # 10603
DIGIKEY PART # 1568-10603-ND
MFR PART # 12573
DIGIKEY PART # 1568-12573-ND
DESCRIPTION Tweezers ESD Safe, Self Closing Pointed Very Fine
Screw Driver Kit
MFR PART # IF145-475-1
DIGIKEY PART # 2434-IF145-475-1-ND
MANUFACTURER iFixit
DESCRIPTION Hex, Pentalobe, Phillips, Slotted, Torx®, Torx® TR (Security), Triangle Socket Bit, Screwdriver Set
Flush Cutters
MFR PART # DKS-FLUSH-CUTTERS
DIGIKEY PART # DKS-FLUSH-CUTTERS-ND
DESCRIPTION Cutter Flush 4.70" (119.4mm)
Small Needle Nose Pliers
MFR PART # PN-2004
DIGIKEY PART # 1691-1422-ND
MANUFACTURER American Hakko Products, Inc.
DESCRIPTION Standard Pliers Short Nose Smooth 5.75" (146.1mm)
Wire Strippers
MFR PART # 404080001
DIGIKEY PART # 1597-1537-ND
MANUFACTURER Seeed Technology Co., Ltd
DESCRIPTION Tool Single Level Stripper, Multiple Presets For 20 ~ 30 AWG Cable
MFR PART # DKS-STRIPPER6MM2
DIGIKEY PART # DKS-STRIPPER6MM2-ND
DESCRIPTION Tool Stripper and Cutter For 0.08mm² ~ 6mm² Cable Cross-Section
Eye Protection
MFR PART # 11819-00000-20
DIGIKEY PART # 3M158398-ND
MANUFACTURER 3M
DESCRIPTION Safety Glasses Clear One Size
Non Mounted Tools
Soldering Iron Tip Cleaner
MFR PART # DKS-SLDCLN
DIGIKEY PART # DKS-SLDCLN-ND
DESCRIPTION Holder Included, Metal Brass Wool Solder Wire Scouring Pad For Use With Soldering Irons, Workstands
DATASHEET Not Available
Helping Hands Solder Station
MFR PART # DKS-HLP-HNDS
DIGIKEY PART # DKS-HLP-HNDS-ND
DESCRIPTION HELPING HANDS SOLDER STATION
ESD Mat
MFR PART # DKS-ESD-MAT
DIGIKEY PART # DKS-ESD-MAT-ND
DESCRIPTION Floor Grounding Mat Black 1.8’ (0.55m) X 1.17’ (0.36m)
Page Links
Click Here for the 3D Step files
