------Question for 15455 Please Put your question below------
What size screwed are shipped with this product? The data sheet does not show dimensions for hole cutouts for a panel mount. What does the manufacturer recommend?
Hello scott.hansen,
Welcome to the TechForum, they give no recommendation because they don’t know how thick your panel will be. Per the datasheet the shell has M3 nuts and you would need to get the length you need.
Sparkfun lists the following information about the screws
