MR Strain Relief missing parts needed
------Question for 350373-1 The 6 position MR clamshell Strain Relief does not come with the #4 closure screw or the rubber wire ferrule. What are the part numbers for these required components? Thanks
I was unable to find a screw part number on TE’s website, but I found part A34928-ND as a possible option for the rubber ferrule. Is this what you were referring to?
@apwunodine
According to the drawing, it requires a #6 pan head type “B” self tapping pan head screw, 9.53 [.375] long.
I could find some screws match this requirement.
I hope this could help you.
Best regards,
Thanks for the replies. I found “BUSHING SPLIT 0.156" PVC BLACK 2-350377-0” Link: 2-350377-0 TE Connectivity AMP Connectors | Cables, Wires - Management | DigiKey to probably be the size ferrule for 4mm outside diameter wire/cable. I wish the DigiKey website listed the accessory options with the connectors. What good is a clamshell strain relief without the screw to secure it closed and the ferrule/grommet/bushing to secure the wire to it? Not knowing the nomenclature used for the “bushing” made locating them on the website impossible for me. On the plus side, I’m a new customer to DigiKey and I am very impressed with the expansive product inventory and this support forum! Thanks again for the help!
