MTPD1346D-100 - Maximum Optical Power and Current
What is the maximum optical power the MTPD1346D-100 photodiode.
Greetings,
Such a question is difficult to answer in a meaningful way without additional information on the intended application.
The maximum permissible die temperature is one likely limiting factor, and how soon it will be reached in relation to incident radiation will depend significantly on ambient temperature and any reverse bias applied. Temperature-dependent device behaviors such as noise or dark current could also become limiting factors in some cases, though the extent to which it is so would be highly application dependent.
Considering the limited information contained within the datasheet, it may be expedient to contact the supplier directly in such a case.
The application is to measure the laser power and generate 1mA by the diode, Can this diode handle 1mA current output. The specification does not inicate much it mentions only 180 µA at 1300nm
Again, discussing your application requirements with Marktech directly would likely be expedient, considering the limited information in the datasheet. Their contact page may be found here.
