Multi-Purpose Touch Screen DIY Project - OctoDash Application
Build a mobile OctoDash setup using a DIY touchscreen assembly and a Raspberry Pi 4 that can provide almost any 3d printer wireless print uploads and many upgraded features.
Click here to see the parts list
Multi-Purpose Touch Screen DIY Project - Octodash Head Unit
Before starting please know that the majority of this project has already been covered in creating the display unit below.
Tools Used
MFR PART # 32305
DIGIKEY PART # 1742-32305-ND
MANUFACTURER Klein Tools, Inc.
DESCRIPTION Hex Socket, Phillips, Slotted, Square, Torq-Set® Bit, Screwdriver Set
DATASHEET Click Here
MFR PART # 53104
DIGIKEY PART # 53104-ND
DESCRIPTION HIGH-SPEED DRILL BIT - 1/8’’ BIT
Electronic Components Used
The only difference between the models below is memory size and price. I used the 8GB RAM version, which is unnecessary for the application. Any of these will work.
RASPBERRY PI 4 B
DK Part Number MFR Part Number Memory
2648-SC0192(9)-ND SC0192(9) 1GB
2648-SC0193(9)-ND SC0193(9) 2GB
2648-SC0194(9)-ND SC0194(9) 4GB
2648-SC0195(9)-ND SC0195(9) 8GB
I have noticed that with consistent use and long prints, this board does get a little hotter than I would like so I put this fan/heatsink kit on it. That is no longer an issue; I believe it is money well spent and will be rewarded in longevity.
MFR PART # 114992661
DIGIKEY PART # 1597-114992661-ND
MANUFACTURER Seeed Technology Co., Ltd
DESCRIPTION Heat Sink Raspberry Pi 4B Top Mount
VIDEO CONNECTION
The Raspberry Pi 4B utilizes a micro HDMI video Jack. The Seeed 7" Touch screen utilizes a full size HDMI video Jack. While it is true that a cable can be purchased that will connect these two devices I find that they usually stick out a lot further than I would like. The three parts below create a cleaner, low profile look in my opinion.
Image Image Image Image
MFR PART # 3549 3561 3557
DIGIKEY PART # 1528-2363-ND 1528-2375-ND 1528-2371-ND
MANUFACTURER Adafruit Industries LLC Adafruit Industries LLC Adafruit Industries LLC
DESCRIPTION DIY HDMI Adapter Board
Position Ribbon Cable 7.874
(200.00mm)
DATASHEET Click Here Click Here Click Here
