Multi Purpose
This Product Selection Guide contains information to help select products in the Multi Purpose category on DigiKey.com
Products in the multipurpose contact family are interconnect system components which are typically applied to a conductor by means of a crimp connection, which can be used with multiple styles of corresponding housings. This allows the use of the same contact part number and application equipment to assemble similar connectors which are resistant to incorrect mating.
SelectionCharacteristics
Type: Indicates the specific style of the contacts.
Pin or Socket: Indicates whether or not the contact is pin or socket.
Contact Termination: Identifies how the contact attaches to the wire, such as crimp or solder.
Wire Gauge: Indicates the wire size or size range with which a product is designed for use.
Contact Material: Indicates the material composition of the contacts.
Contact Finish: Indicates the finish/plating material applied to the contacts.
Contact Finish Thickness: Indicates the thickness of the finish/plating material applied to the contacts.
ProductExamples
MFR PART # 2091117
DIGI-KEY PART # WM1103TR-ND - Tape & Reel (TR)
MANUFACTURER Molex
DESCRIPTION Socket Contact Tin Crimp 18-22 AWG Power
DATASHEET Click Here
MFR PART # 170360-1
DIGI-KEY PART # A97686TR-ND - Tape & Reel (TR)
MANUFACTURER TE Connectivity AMP Connectors
DESCRIPTION Pin Contact Tin Crimp 18-22 AWG Stamped
MFR PART # 0462-201-16141
DIGI-KEY PART # 1734-1326-ND
MANUFACTURER TE Connectivity Deutsch Connectors
DESCRIPTION Socket Contact Nickel Crimp 16-20 AWG Power, Machined
If you have any general questions on the specifications for selecting Multi Purpose, please reply using the button below. If you have questions on specific Multi Purpose please post those questions in the Connectors, Interconnects category.
