My question is about the above product is for under ground water pipe leakage detector
------Question for WD3-LP-D2-10 Please Put your question below------
Welcome to the DigiKey TechForum. It’s not specifically mentioned but looking at the datasheet it appears this sensor would not work for underground leak detection unless you had an area with access to the pipe and you are concerned about leaks for example in like a water pipe control room.
