Need a custom cable assembly
I need
HDP14S - AE14G(300MM length) - AKC14H pre assembled. Our company buys about 100 of these a year. How do I order this custom assembly? Thanks
Hello Bellison,
Thank you for contacting the TechForum.
I am sorry to inform you DigiKey no longer offers that assembly service.
Thank you for letting me know! Do you know what tools are required to assemble those parts?
bellison, I am a little confused on the parts being requested. When I search for “HDP14S - AE14G” I get this selection:
Various Assemblies List
When I search for AKC14H, I get these.
Could you provide which part numbers for the connectors you need and the cables you’d like? That will help us narrow down how to best help you.
AE14G is ribbon cable, I am not allowed to post more than 2 links at a time CBL RIBN 14COND 0.05 GRAY 300’
HDP14S-ND https://www.digikey.com/en/products/detail/assmann-wsw-components/ADIP-14Z-LC/924318?s=N4IgTCBcDaIBIBEAKBGALAZQLQDkEgF0BfIA
AKC14H-ND https://www.digikey.com/en/products/detail/te-connectivity-amp-connectors/1658621-2/825400
Going to need to cut the cable into 12" sections and make with the male on one end and the female on the other
Hello bellison,
You will need a vise, to press the pieces onto the cable.
An example of the press is 502PV-ND
You will also need the IDC conversion kit, which is 506PV-ND.
Then to protect the male pins of the HDP14S-ND connector, you will need the DIP base plate, with the 0.3" spacing of the slots, like 512PV-ND.
The AKC14H-ND will not need any special base plate, so you can use the same base plate to press that one together also.
Bellison, for the “TE” side, I’d recommend reading through this document that they provide:
Assembly Guide
Tools similar to these would be needed for any IDC installation. I don’t see specific tools mentioned for the Assmann side.
David made some good suggestions on specific options.
Thank you Nathan, Kaleb and David! You saved me a lot of time and effort.
