I have a bunch of Zebra Triggers that have degraded over time due to the buttons failing. They are these little dome-like metal things, like a toy popper, about 4 mm millimeters in diameter with a very slight arch. When you press down on the plastic they are adhered to, they collapse and make contact with the pad underneath to trigger the scanner. I thought they were dome switches and ordered some, but if they are, they certainly aren’t the kind I ordered.
What are these and how can I get more like them?
In our system what you have would be considered a Tactile Switch of the Snap Dome variety, < Click Here >
I don’t see that we have a visual match to your switch.
I had ordered the SKRWANE030 and SKRWAME030, but those were the wrong things. Is there a better replacement for this?
There isn’t one that I can find.
What about something like 5134TR?
How does 5134TR compare to the one you have?
That’s about double the diameter and definitely won’t fit. I pulled out a hex head that’s 4mm and that fits almost perfectly over my switch. Are there smaller options? I think that height might be close, but it’s not listed in your diagram.
