Need an Identical replacement for PN XT484R24
What Part would be an indentical
replacemennt for PN XT484R24
Hi mikee,
Welcome to the TechForum.
I could not find any relays with the identical pin spacing as the XT484R24.
That relay is designed to fit into a DIN rail socket and be mounted to a DIN rail. As such, you may want to consider the DIN rail relays in the following link, which are functionally quite similar, including coil voltage and load current ratings.
These come already mounted to a DIN rail socket, so fitment of the relay itself is not a concern. However, the DIN rail sockets are of various dimensions, so one would need to verify whether you would have the space needed to fit one of these on your DIN rail.
