I could use some help finding a suitable replacement for the resistor in the picture below. I tried the Resistor Color Code Calculator but this particular 5-band combination is not allowed in the tool.
Thanks in advance!
Thanks in advance!
220Ω 5% would be a reasonable guess. Extra black band may be meant to indicate a temperature coefficient, or perhaps a failure rate if a mil-spec item.
