Welcome to the DigiKey TechForum. You will need to verify the size but what you have is probably one of these Wurth capacitors.
Of those that @Steve_Fellman linked to, it would appear to be the 865060353009, as that is the “ASLL” series, and your part is marked with “ASLL”.
The 865060353009 has an 8mm diameter and height of about 10mm.
thank you very much
