I have pictures, but it is hard to get a good angle on the part markings as it has been bulged when it went out. The customers son had plugged in a 12v charger into a 5v system and that seems to have done it.
I have a suspicion it could be a XC6101B440MR-G but am looking for some second or third opinions.
It looks to be marked as 0B9K or 089K. If there is an alternative that would be great otherwise as I was not able to find stock of the part number I thought it was.
What informs this suspicion? Interpreted device markings alone offer little basis for those on the other side of the screen to formulate a response.
Package information (dimensions & lead configuration) would be helpful. Observing adjacent devices to which the part in question is connected (and how) may also provide useful cues in a repair context.
Such has been the end of numerous things. Partial standardization around barrel connectors over the years is inviting toward such events.
I think the lead configuration can be seen in the picture. The unit is 3mm long and 1.6mm wide and 2.8mm to the outside of the legs. I’ve pinned it out to some extent and added the info for that in a second picture.
This is apparently a CMOS LDO with enable and bypass pins.
Would guess it is a 3.3V fixed and you could try just replacing it with a similar, such as MIC5318. (Note; The on-board chip’s EN pin polarity is unknown). The board design is poor, as the LDO does not have input decoupling cap nearby.
Hi ATSolutions,
I propose my version of the desired microcircuit.
It could be a high-current, high-speed LDO regulator, from the XC6210 series—specifically, an XC6210Bxxxxx model.
You will find all the necessary information in the datasheet.
The hypothesis is based on statistics. Could say 95% of LDOs on SOT23-5 or SOT25 package share the same pinout (only pin 4 varies based on type, sometimes pin 3 too). If it is an LDO and it blew up with +12V, it is likely a CMOS. Could you list all the ICs (marking, pin number) where the signal from pin 5 goes?
Not sure if you are still interested in working on this just for curiosity, but my customer did not want me to spend the time to figure it out any farther.
I don’t mind to go through the board and send you the info if you wanted.
