I am looking for high voltage 150vdc and 100amps N channel mosfets for large inverter project.
The surge voltage and current draw is popping smaller mosfete befor the unit settles down to operational levels.
Roy
Roy
Hello epecltd,
What kind of N -Ch. MOSFET package do you need?
Also, we need to know other parameters: Vds, Rds, Id, Vgs
Welcome to the DigiKey TechForum. Here are some options you can browse through. Can you explain your application to us, what is the part number of the MOSFET you are using that is popping ?
