20uf 20% 10V X5R 0402
Options were grayed out…
For options that are 20µF the sizes we have are larger than 0402(~1.00mm x 0.50mm)
Ceramic Capacitors | Capacitors | DigiKey
For the 0402 size the closest option to the specification given that I see are 22µf options.
10V X5R Ceramic Capacitors | Capacitors | DigiKey
Ah man. I have to have 0402.
Hi theupel2,
The part you need is the following (linked by @nathan_2268 above):
20uF is a non-standard value for a ceramic capacitor (they exist in some special cases, but generally not in an 0402 X5R 20% tolerance form). I cannot think of a single circumstance in which a 22uF 20% tolerance X5R spec part would not work as suitable alternative for a 20uF 20% tolerance X5R cap.
It is for NAND memory 2.5v circuit in MacBook. It is very common, I use it daily. But I mostly pull them from old MacBooks.
I am not engineer or anything fancy, just a microsolderer. Are you sure it won’t be an issue, LOL : )
Absolutely positive.
These types of capacitors are just used to store charge locally for the nearby chips as they suck current in fits and starts, and having a tad more capacitance (on average, as the tolerance on these parts is already 20%, which is +/-4uF) allows them to store a tad more charge, which is a good thing.
I’m pretty sure they would use higher capacitance values if they could, but maintaining a 10V rating and a 20+uF capacitance is pushing the state-of-the-art for such a tiny capacitor. That’s why there are relatively few options available – the higher the value for a given size and voltage, the harder it is to produce.
