Need size info
------Question for SA1012 Please Put your question below------i am looking for a silderable power pin that is 3.5 mm diameter and at least 1/2 inch long. I need to carry 15 amps DC. The spec sheet does not list any size information for this pin.
Hello jmstana51 and welcome to the DigiKey TechForum.
While I could not confirm the exact dimensions of SA1012, from what I could find, it does not appear to have a 3.5mm diameter.
While we do not filter contacts by dimensions, I did look through some of the options we have for solderable pins, and even some of the larger ones I saw only have a ~1.8mm diameter pin.
