Need spec sheet also
------Question for EVC-116-3400 Please Put your question below------
I also need the specs for this to ensure it is the same as the EVC-122-3400. Also wondering if this is liquid cooled only (no fan) and if it supports J1772.
Checking on this now. Will let you know when I have the answer.
@k11
Here is the datasheet for the series.
Datasheet-EVC-3400.pdf (847.9 KB)
From the datasheet, the EVC-116-3400 is a cold-plate type, and does not support J1772.
