I purchased one Vishay Dale CWE-1.0KRCT-ND, CW0101K000JE73RES, 1K OHM 13W 5% AXIAL. I needed about 1.5 inch leads for my project, but the resistor had 1 inch leads which were just a bit shorter than would work for me. The data sheet diagram showed 1.5 inch minimum length, though I see now that there is a footnote that says for some reel pack methods the leads may be trimmed to a shorter length. That’s on me. I got unlucky.
Can you recommend a 1K Ohm wire wound resistor with similar specifications but that definitely has 1.5 inch+ leads, or very close? 1 inch won’t do. Unfortunately(?), I really only need one of them.
Hello @matthew.cottrell,
Welcome to the TechForum!
You could consider selecting products from this list: 1 kOhms Axial Through Hole Resistors | Resistors | DigiKey
Note that I have opened the size to include 15 W devices.
Out of curiosity, what is the application for your resistor?
Cordially,
Thank you for the quick response. The project is nothing very interesting. I’m just putting together some simple capacitor discharge devices with resistors and dual banana plugs. The 10k resistor had nice long leads but the 1k was too short to fit. I might take a chance on finding one with longer leads, but it seems like it’s hit and miss since lead length obviously isn’t the most important specification in the data sheet. In the meantime, I just soldered some extensions on the leads. It’s not the most elegant solution, but it works ok.
All the best.
Disagree, things like this are always interesting.
Happy soldering!
Sincerely,
Aaron
