------Question for BU5086E When do we get a real datasheet
Hello @rtoftness,
Sorry, unable to locate the datasheet either from the OEM distributor or the OEM.
A request has been submitted to update the page.
Do you have a specific question regarding this relay or this class of relay?
Sincerely,
Physical dimensions so that I can model it and use it in a mechanical enclosed design.
The information the supplier has on their site, is less than the information that is provided in their provided datasheet. The datasheet only provides general dimensions of 1.5" (37mm) Wide x 3.4" (88mm) Depth x 2.75" (72mm) Height.
Thanks. at least I can get an outline
