10-16-26 >
Got my shipment ~ 6PM..checked contents against the parts I wish them to replace.
My original parts were Nichicon GQ -180uf 450v- ..which a search states were replaced by either the GR or LGR series. I chose the LGR for the longer MTBF operation hours .
A visual comparison shows the height of the can(s) was virtually exactly the same at 36mm. This was my biggest worry as the board on which they mount sits snugly against another board and both sit in a sub chassis with just as tight constraints against the back plane of a much bigger chassis.
BUT the new parts can diameters looked wrong, and when laid against the original parts I had a problem caused by the tight positioning of the original parts on the board.
I threw a micrometer into the duty and found the new parts were each almost a perfect 5mm larger diameter than the originals .
Originals (GQ) were 30.45mm Diam by nearly perfect 36mm length…while the new caps (LGR) are 35.22mm Diam by 36mm. Almost a full 5mm diameter difference PER CAP…adding a nearly perfect 10mm extra space requirement an subsequent pin to board misregistration.
The original caps fit tightly nestled against other parts ,and while I might get one of the new caps to fit the area and register properly into the printed circuit thru holes ..the other cap would be displaced off to the side so far as to not hit it’s holes …AND would be crushed against the other parts.
BOTTOM LINE..I can't use the new caps due to a silly 5mm diameter difference in them and the originals.
I trusted the GR/LGR cross as having the same dimensions -or perhaps smaller given the design being 25 years newer) ..and in can height THEY DID..but not in diameter .
Please check your specs and see if there is something equal to -or smaller - in dimensions to my original caps...and I hope that I may return these LGR's and get 2 (preferably 105 Degree -**[u]at least[/u]** 2K Hrs running MTBF ) caps.. I don't mind paying return shipping and hope that most of my original purchase price will pay for most of what you find that fits the original GQ's dimensions .
