Obsolete transistors or out production
Hello, I would like to know which transistors I could replace the following with, as they are obsolete, and which have the same pinout:
C828 R
C828 S
2N4916
Thank you
Juan Fernando Lozoya Favela
@juanflozoya
For each I found the below as most similar.
For the C828 R and S, would you have a data-sheet for these?
For the 2N4916-ND I found the 1514-PN4917PBFREE-ND.
I am sorry to say that I am not seeing a stocking match or would have the same pinout.
PN4917 PBFREE Central Semiconductor Corp | Single Bipolar Transistors | DigiKey
2N4916.pdf (254.6 KB)
PN4917 PBFREE.pdf (297.0 KB)
@juanflozoya
It may be the case that the C828 items you reference are the 2SC828.
The below was used to find similar options
2SC828.pdf (53.8 KB)
If that is the case the below link
NPN Single Bipolar Transistors | Discrete Semiconductor Products | DigiKey
