Is there a sealed/ weather resistant option for this relay? Ideally something with a IP68 rating?
Our environment is very dusty / damp and these relays have caused more downtime then any other components.
Greetings,
It may be worthwhile to pay attention to precisely how the relays in question are failing. A dirty environment isn’t going to help matters at all, but if they’ve been under-specified or misapplied electrically, the same failures would still happen even in a class 1 clean room.
The G3TA series does exist as a solid-state alternative with no moving parts that should fit mechanically, but there are no corresponding double-throw options and the actual switching devices are substantially more delicate.
Agree with rick_1976, first check how they fail. Contact weld from inrush is different story from dust on the armature.
For dusty/damp we stopped using open relays in the field. Two ways that worked:
SSR like G3TA is good if you only need one direction and can live with leakage and heat. For changeover contacts sealed electromechanical is usually simpler.
How they fail for you - stuck closed, no pull-in, or intermittent?
