I’d like to share a free, open-source KiCad plugin that streamlines the process of exporting manufacturing files for PCB/PCBA production.
The Challenge:
Preparing fabrication files for PCB manufacturers often requires manual file renaming, BOM formatting, and ensuring compatibility with different fab houses—especially when working with Chinese manufacturers like DIYIPCB, ELECROW, JLCPCB, PCBWay, NextPCB, ALLPCB etc.
The Solution: Fabrication Toolkit for All
This plugin automates the entire export process and generates production-ready files that are compatible with virtually all PCB manufacturers.
Key Features:
- Standardized Gerber Export:
- Automatic generation with industry-standard extensions:
.GTL/.GBL(Top/Bottom Copper).GTS/.GBS(Top/Bottom Solder Mask).GTO/.GBO(Top/Bottom Silkscreen).GML(Board Outline)- Separate
.PTHand.NPTHdrill files
- No manual renaming required
- Optimized BOM for PCBA:
- Includes columns for LCSC Part #, Manufacturer Part Number, Datasheets
- Smart DNP (Do Not Populate) handling
- Generates both full BOM and production BOM
- Pick-and-Place Files:
- Standard CPL/PNP format with correct coordinates and rotation
- Compatible with assembly houses worldwide
- Universal Compatibility:
- Works with ALL major Chinese PCB/PCBA manufacturers
- Also compatible with international fabs
- Vendor-neutral export (optional DIYIPCB integration available)
Why This Matters:
By standardizing the export process, this plugin reduces the risk of manufacturing errors and saves significant time in the design-to-production workflow.
Getting Started:
- GitHub Repository: GitHub - DIYIPCB/Fabrication-toolkit-for-all: Free, open-source KiCad plugin to export manufacturing files (Gerber, drill, BOM & PNP) for PCB manufacturers worldwide. Includes one-click file import to the DIYIPCB PCB ordering page. Supported by DIYIPCB. · GitHub
- License: MIT (completely free and open-source)
- Compatibility: KiCad 8-10 (Windows tested, Linux/macOS validation ongoing)
We Welcome Feedback:
As members of the KiCad community, your input is valuable. If you encounter any issues or have suggestions for additional manufacturer requirements, please:
- Open an issue on GitHub
- Reply to this thread with your experiences
Thank you for your time, and happy designing!
