Optical Fiber
Dear Team,
There is no coating diameter mentioned in your website. I am searching the Optical fiber with following specifications. Can you connect me with your technical team.
Purpose Illumination only
Coating Diameter less than 125 microns
Cladding Diameter NA
Core Diameter NA
Material of coating layer Biocompatible material
Operating Wavelength 632 nm
Bend Breaking If we bend the fiber mechanically with in the diameter of 10 mm, the fiber should not break
Hello chiranjeev.gopal,
I’m sorry to inform but we cannot filter by coating diameter nor operating wavelength. For bend radius of 10mm and smaller, down to 5mm for example, we have the following options: Fiber Optic Cables | Electronic Components Distributor DigiKey
Since a lot of those results are marketplace products they don’t seem to have good data sheets on our website to observe other parameters in more detail. One would have to locate the data sheets to see if the coating diameter is listed by the manufacturer along with the wavelength. For example the data sheet: https://www.l-com.com/Images/Downloadables/2D/FOB-MFD-12FSMR-M_2D.pdf only mentions the wavelength there and the buffer, not the coating diameter.
Sorry for the inconvenience.
