Output voltage trimming
------Question for LRS-1200-48 Please Put your question below------
Can the output voltage be varied to get closer to 50V?
Yes, the voltage can be adjusted to 50V.
There is a note on the voltage adjustment:
3. Voltage adjustment can only be operated within the input range of 220-277Vac. If the voltage adjustment is performed outside this range, it may cause abnormal output.
Datasheet
