Parameter Sheet
------Question for PD-9601GC/AC-JP Please Put your question below------
I would like to order two items. Is it possible to issue a certificate of eligibility?
A Classification Determination Certificate is a document that indicates whether goods or technology intended for export fall under the scope of regulations (list control) under security trade control (Foreign Exchange and Foreign Trade Act). It is a document prepared by the manufacturer based on the product’s specifications, determining whether it is “applicable (requires permission)” or “not applicable (generally not required),” and is used as a document to be submitted to customs. Detailed overview of the Classification Determination Certificate: Based on Annex 1 of the Export Trade Control Order and the Annex of the Foreign Exchange and Foreign Trade Control Order, it determines whether there is a risk of use in the manufacture of weapons of mass destruction or diversion to conventional weapons. Uses: Customs clearance procedures, internal security trade control documentation, submission to business partners. Contents: Product name, model number, applicable regulation number, determination result, and basis for the determination. How to obtain: Request from the manufacturer: Major manufacturers allow applications via their website forms (often takes 1-2 weeks).
Hello miyagata,
The closest similar item I found, is a Certificate of conformity, which is handled by our Customer Resolution department. Their email address is customer.resolution@digikey.com.
You can check with that department, to see if they can supply the Certificate of Eligibility.
