------Question for NVR-04 Please Put your question below------
Hello, this PN# is not stocked, however, the website does offer “parametric equivalents”. The PN# I am looking for is a connector and, as we all know, all mechanical dimensions matter. Is it safe to assume that by “parametric equivalent”, the alternates suggested will fit mechanically?
It looks like the alternatives shown are from a different series, so while they have the same pin count and spacing they will still have differences in the molding meant for another type of connector. I was unable to find a proper alternative for this connector.
Suggested alternatives described as “parametric equivalent” are machine-selected based on similarity of listed parametric data on fronts of most common interest in typical use. They should be understood as pointers to items that are of potential interest if one is forced to make an alternative selection, but are NOT guaranteed to to be form/fit/function compatible.
This was answered yesterday, however, I appreciate your response as well.
Thank you
