Looking for assistance locating connectors for a 10 wire ribbon cable. I need a solder on connector for the control panel circuit board, the ribbon, and a plug/male connector for the other end. Attached are photos. I believe the “male” end connector would be 732-2102-ND but not positive. The width is about 17mm
The 732-2102-ND would work for a match for the item in your images.
61201023021 Würth Elektronik | Connectors, Interconnects | DigiKey
A board mounted mate for that item 732-2672-ND.
61301021121 Würth Elektronik | Connectors, Interconnects | DigiKey
Thanks Nathan for the quick reply. I was actually hoping to just replace the “top cap” portion that pinches the ribbon to the board. I am sure if I try to remove the original, part labeled fd10ph i will break the little tabs on it. What would a top piece or a complete assembly be for part numbers? Second is the ribbon itself available in something around 3’ or so? The part is a control for a spa and a mouse has shredded it between the control and the main circuit board. Thanks again.
I found on Amazon below but don’t need 25 of them. Any idea what these would be classified as on Digikey for part number?
They would be found in Rectangular Connectors > Board In, Direct Wire to Board
I present for your consideration:
Please do not hesitate to contact us if you have any questions or concerns.
Kristof Berg
Electronics Technician
P 800.344.4539 x 12649
digikey.com
Thank you very much everyone!
