Part number question
------Question for CA3-B0-24-660-321-C Please Put your question below------
According to the Carling datasheet for this part, there should be a last digit in the part number defining the agency approval. this part has only C which is max application rating.
I was able to verify this information on the datasheet and hopefully it helps you out.
C UL Recognized, CSA Accepted
Approval Agency
CCC, CSA, UL
Bottom right on page 6 of the datasheet Page 5 breaks down the approval information
11th digit is for the approval agency
D VDE Certified, UL Recognized, CSA Accepted
E TUV Certified, UL Recognized, CSA Accepted
H UL489 Construction: VDE Certified, UL Recognized, CSA Accepted
I UL Recognized STD 1077, UL Recognized 1500 (ignition protected),
CSA Accepted
L UL489 Construction: UL Recognized, CSA Accepted
R UL489 Construction: TUV Certified, UL Recognized, CSA Accepted
Thank you
Ryan
Thanks, but that is not my question.
The last digit on the website is missing. What is it?
