Parts DON'T WORK together.- NEED SOLUTION ASAP
------Question for 10127817-221LF Please Put your question below-----
We just ordered 10127815-06LF and 10127816-06LF and 10127817-221LF and 10127818-221LF AND WE CAN’T GET THE PINS/SOCKETS WON’T GO IN PROPERLY
The socket seems to be ok. and I can work a bit and get them in either in the connector. But the PIN will NOT go in either one. I’m not sure why and maybe you can look at the parts and see what is NOT selected properly? THANKS!!!
We need these parts ASAP so if we can order the correct parts we will need them overnighted. THANKS!
@john9
The drawing for the 10127815-06LF shows that the terminal for it would be the “10127817”
As well as the below document.
Amphenol only lists the 10127817-221LF as the orderable item number for that contact.
For the 10127816-06LF the “gs-12-1181.pdf” also indicates that the 10127818 contact would work.
And Amphenol’s site only lists the 10127818-221LF when I search for 10127818.
As for why these don’t work in the on hand housings would you have the item numbers for the crimp tooling you used?
