------Question for TCG121XGLPAPNN-AN20 Please Put your question below------
passende Touchpanel
passende Touchpanel
Hello jon_11475
Thank you for your reply. Is this the touchscreen for the TCG121XGLPAPNN-AN20 display?
Or do we not need the TCG121XGLPAPNN-AN20 display at all, but would instead use the TCG121XGLPBPNN-AN40 display, which includes a touch function?
Thanks in advance for your quick reply.
Best regards, Robert
Diese E-Mail enthaelt vertrauliche und/oder rechtlich geschuetzte Informationen. Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtuemlich erhalten haben, informieren Sie bitte sofort den Absender und vernichten Sie diese Mail. Das unerlaubte Kopieren sowie die unbefugte Weitergabe dieser Mail ist nicht gestattet.
This e-mail may contain confidential and/or privileged information. If you are not the intended recipient (or have received this e-mail in error) please notify the sender immediately and destroy this e-mail. Any unauthorized copying, disclosure or distribution of the material in this e-mail is strictly forbidden.
Sorry for the confusion earlier. I had assumed you were looking for a replacement for the TCG121XGLPAPNN-AN20.
Please refer to link HERE to explore touch panel options.
I was only able to find part number KDA-121-19013S-A, which appears to be compatible with the TCG121XGLPBPNN-AN40, but not with the TCG121XGLPAPNN-AN20.
Unfortunately, KDA-121-19013S-A is not currently available in the DigiKey catalog. I recommend double-checking compatibility directly with Kyocera to confirm if there’s a touch solution for the AN20 model.
Best regards,
Jon
Great, thank you very much. I will write to Kyocera.
