Hi Robert,
(kernel version: 4.19.50-ti-r20)
When I try to
config-pin P9.24 can and config-pin P9.26 can
I got the following error:
ERROR: open() for /sys/devices/platform/ocp/ocp:P9_24_pinmux/state failed
ERROR: open() for /sys/devices/platform/ocp/ocp:P9_26_pinmux/state failed
I found that the pinmux for both are not listed under :
The above is booted with CAPE on. But without CAPE, both pinmux are there.
Is CAPE Overlay not loaded or is CAPE Overlay conflicting with something else.?
What the best way to resolve it?
Hi @dzhou, sorry i’m confused, does CAN1 work out of the box with out touching config-pin?
config-pin is used to quickly change the pinmux of pin’s on the fly. However when you load a device specific overlay, that ability is removed, as the overlay has a specific pinmux for the device, such that i’ll just work.
So, out of box with that BeagleBone Cape, the CAN1 bus should be muxed and working, if not we have another issue to deal with…
We got CAN working. Buster (2019-07 version) is just fine without recompiling overlays. Just config pins. We have our end problem, the mode control is implemented on our board. After grounding the pin, it just worked.
