Please generate orderable part nr for KEL 8832E & 8802
I want to place an order for the following KEL connectors, but they are not in your catalog, so I can’t even request a quote for those.
Can you add them to your catalog ?
- KEL 8832E-050FS-N-F
  • KEL 8802-050-170-F
(Looking to order 30 of each)
Thank you in advance,
T.
Greetings,
Unfortunately this is not a request that DigiKey can honor at this time.
Due to a history of it being a labor-intensive process yielding very little in return, DigiKey has chosen to limit the circumstances under which requests for non-catalog product are accommodated.
A variety of other 50-position, 1.27mm connection systems are available. If you’d care to describe your needs, we’d be happy to offer suggestions.
Thanks for the quick reply.
I have legacy hardware,
1 main cpu board connected to
2 daughter boards via those connectors (I think, all dimensions / the drawings match),
enclose tightly in its legacy case.
I’d like to build replacements for those 2 daughter boards,
hence I’m searching for connectors that are as close as possible to those.
