Power cord needed 5034-XC400-ND
do you sell a power cord for this item? 5034-XC400-ND
https://www.digikey.com/en/products/detail/intuicom/XC400/19187992
Hello @ainjian
According to the manufacturer’s datasheet, it’s powered through a locking terminal block with a 9-48 VDC input (150 mA idle and 450 mA peak at 12 VDC), so you’ll need to select a power supply within those specs and wire it to the terminal block (something like part number 1827716, I was unable to verify dimensions.)
