Hi,
Does DigiKey have the capability of pre-programming the ESP32-C3-Mini-1 radio module? If so, what is the cost per unit?
Thanks!
John
Hi,
Thanks!
John
This item is listed as “Not Verified” for the “DigiKey Programmable” field.
In the case of items being listed this way you would need to e-mail Custom.Orders@digikey.com to request if they are able to program these for you.
When you e-mail them please be sure to supply the full DigiKey order number for the specific in-stock item you are looking to have programmed.
You would need to also supply the code that you would like to have on it too.
Thanks Nathan!
Hi Nathan,
As per your suggestion, I emailed Custom.Orders@digikey.com but I have not heard back from them. Can you assist with this??
This particular part number indicates it is programmable. The part I want to use is the ESP32-C3-MINI-1U and the difference is that the -1 has the etched antenna while the -1U has the W.fl connector so I would assume that if you can pre-program the -1 you should be able to pre-program the -1U
I am sorry for the delay on this. I am not able to assist directly. As the custom orders team work from their e-mail in-box it may take time depending on the queue length.
I would recommend that if they had not gotten back to you, that you would call the 1-800-344-4539 and ask to either speak with them or the customer resolution team to have them reach out to that team on the status of the request.
