Price for MS3116F10-6P wrong
------Question for MS3116F10-6P Please Put your question below------
MS3116F10-6P SPI Connects | Circular Connector Assemblies | DigiKey Marketplace
it seems that the price for one unit is wrong (10 times what it should be). Can you correct? Thanks
Welcome to the TechForum.
I agree those are not in line with 1 part but due to these needing a 50 minimum quantity to order from the Factory those prices were set by SPI Connects in the Marketplace. We have options to buy them much cheaper but need to adhere to the minimum quantities from the manufacturer.
Link to most options of this connector.
Receptacle, Male Pins Circular Connector Assemblies | Connectors, Interconnects | DigiKey
Thank you
Ryan
The 2899-MS3116F10-6P-ND looks like another option to consider. This is also a Marketplace product, so shipped directly from the respective Marketplace company, Air Electro Inc..
Unit pricing is much more reasonable, though I haven’t checked on shipping costs or regional availability.
thanks, but the one you point at sell only in quantities of 5
jmgm,
We do not have it in stock, but one that can be order as 1 piece, is part number IMS3116F10-6P-ND.
Looking for similar connectors that we have in stock, you can Click Here for the available options.
Please check th datasheets to verify compatibility to your application.
yes, I have seen this one (that is not on stock), that is why I was looking for another in the listing. The alternative you point at looks in principle feasible. However, we have not good experience ordering from another vendor, as the pins fit but not the locking part of the connector. The ones we use are MS3116F10-6P (and MS3116F10-6S which you have on stock), so I try to maintain the same part number. But thanks for your answer
