I need to know the production date on the ones you have on stock of these Kester Solder parts: 24-6337-9713 and 24-6337-9727
Hello @kathrine ,
Thank you for your query!
We are unable to provide specific date codes of what we have in stock prior to shipment.
However, If you require the Date code to be within a specific time you could specify those requirements in the order notes at the time of order.
If the date code is in your order notes, our warehouse will fill your order with the appropriate stock. And if that is not possible, our customer service team will contact you to see if the date code we do have is acceptable by you or if you would like to cancel that part of the order.
Regards,
Aswin
Hello @kathrine
If you are looking for the manufacturer date code,please note that DigiKey does not provide date code information prior to an order being placed.
If you require a specific date code for your order, please include your date code preferences in the order notes. Our sales team will inform you if the part within that specific date code is available or not.
