Programming BT40F bluetooth module
------Question for BT40F Please Put your question below------
Hello, Roy. Welcome to TechForum!
Presuming your question is “how do I probram this BT40F module?” I would start with the product documentation, here: BT40F_BT40N Product Specifications. This specification includes application examples you can use to help get a leg up. Fanstel also has a large document library, here: Download BlueNor Document — Fanstel. Any programming tips I can find in the documentation seemed to be aimed at programming the evaluation board or the internal load capacitors, but hopefully these resources are a start.
Can DigiKey program this device? That’s the question I was trying to ask, but couldn’t finish the message.
Thanks,
Roy
Ah, I understand.
Apologies Roy, this is not currently a DigiKey programmable device.
