I am trying to locate a SATA drive connector for a PS4. This is a rt angle on motherboard. The only identifier is the connector is marked TE 14322 DM. The number does not find anything.
I can not find this part number available to us from the manufactures we carry. It maybe a custom part.
Hi jmcloud56,
Thanks for your inquiry. This may use a 2.5-inch SATA HDD, the type similar in a laptop. Since these may have size variations, to fit a PS4 I believe it will need to be no greater than 9.5mm in depth or it may be too big for the hard drive enclosure drawer. I don’t see we carry these but I found one on Ebay that you can verify if it will work for you: https://www.ebay.com/itm/372749968827
